Author [ES] [MY] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: How do I swap locks form one pannier to another, I have both keys  (Read 895 times)
Offline Blackvisor
  • Bike/Model: Tiger 1050 (2010 model
  • City / Town: SE Scotland
I have a larger volume left pannier, which I will use on the right side (I have fitted a low silencer).
How do I remove the lock from my old pannier and fit it into the new one?I have the keys. Luckily the vendor of the old pannier has already removed the lock from that one, and supplied it with the pannier.
THe white pannier is the old one, I want to remove it's lock and fit it to the new one
THis is the white pannier, which has the lock which I would like to remove and re-use in the new pannier
THis is the new larger pannier, which has had the lock removed already
  • Country: Netherlands
Re: How do I swap locks form one pannier to another, I have both keys
« Reply #1 on: 27 March, 2020, 10:22:13 AM »
From the Tiger Explorer 1200 forum
https://www.tiger-explorer.com/index.php/topic,12240.40.html
But take care when pulling the lock out....the springloaded lock plates can pop out of the slots! Don't ask me how I know  :138:
Triumph centerstand, engine guards and heated grips, GIVI PLR6404 side rack, Givi DLM36 panniers, SR6404 topbox rack with M9B plate, Givi V47 and TRK52B topcases, Givi ST603 tanklock tankbag, Evotech radiator and oil cooler guard, ExtendaFenda, Pyramid hugger extension, Puig touring Screen with spoiler, Zumo 396 with Zumolock holder on RAM mount,  Osco chain oiler, SWMotech sidestand extension, CNC shorty clutch & brake levers, SCPROJECT SC1-R can
Offline tiggersteve
  • Bike/Model: 1050 now KTM 1290SAS
« Reply #2 on: 27 March, 2020, 01:51:56 PM »
As above, only way other than drilling it out,
I'm sure someone on here made said tool and put dimensions which seem to be fairly critical for it to work and it may take a few try's,
have a look in the how to section,
« Reply #3 on: 30 March, 2020, 01:20:57 AM »
I made a tool, it worked a treat and I believe it is posted here either in a How To or in another thread. Please don't ask me to go back and dig it out as that exercise consumed a lot of posts and replies. I even sent one to another member so maybe they can chime in. But, rest assured, with the tool I made the removal is the work of 10 seconds to pull the barrel. Drill only if you completely give up as you are highly likely to damage the case. A Dremel and patience are a better way. Posting images here has become too bothersome so I'll not offer to do so but can email you the entire set of pictures and specs with a video too (I think) if you PM me an address....
Offline Trumpet1608
  • City / Town: Winchester
« Reply #4 on: 01 April, 2020, 11:53:28 PM »
I made a tool to get the locks out. I'll have a look tomorrow to see if I can find it. If I do I can post it to you.
All the best
Dick
« Reply #5 on: 02 April, 2020, 12:02:49 AM »
Here are some images of the tool I made.
« Reply #6 on: 02 April, 2020, 12:06:39 AM »
This is the vital dimension. It helps to put a nice 'handle' on the back end of the wire tool to get leverage. This is wire from a locksmith shop, kinda hard and tough. I tried using an Allen key as others have done but it did not work well for me. I have a little video that shows how easily this works, if anyone wants it.
Big hint: Try your tool on a barrel that you have not installed. You'll soon see how it makes the pawl retract. That way, it's much easier to grasp what to do when you stick it in the lock that's mounted in a pannier.
« Last Edit: 02 April, 2020, 12:09:29 AM by ZuluTiger »
Offline Woodie
  • MBD (Multiple Bike Disorder) is a thing innit?
  • Bike/Model: Tiger 1050 2008
  • City / Town: Upper Bucklebury
« Reply #7 on: 07 April, 2020, 01:27:19 PM »
I used an old very small screw driver, that gave me a handle as it makes it easier to manipulate the locking tab.
I was also a lock short but found the old locks were quite close to operating with the relevant keys. with the barrel in a vice I inserted my key in and just filed down the tabs that stuck out, that seemed to work.
My old sprint now has all three boxes using the ignition key (I used to have a bunch like a prison warder)
I never touched it, you can't blame me, it went off when I was cleaning it.
« Reply #8 on: 08 April, 2020, 01:13:34 AM »
 :460: Clever way to save a barrel. Pay attention guys...
Offline Mountainrider
  • City / Town: Stockbridge, MA
« Reply #9 on: 08 April, 2020, 07:59:14 PM »
Thank you all for this thread. After making the tool, I removed the old, and install the new lock in two minutes.  :460:
Took me longer to get the tool right.
« Last Edit: 08 April, 2020, 08:01:25 PM by Mountainrider »
