Author Topic: EBC rear brake pads  (Read 2154 times)
Re: EBC rear brake pads
Reply #10 on: 25 February, 2020, 07:48:30 PM
*Originally Posted by SEG59 [+]
Two years ago I had to strip down the rear caliper when the pads refused to back off, the rubber that cover over the slider pins swell over time and allow road crud in to corrode the pins, this then seizes the pads in situ', I replaced the rubber covers and fitted stainless pins.
  https://www.ebay.co.uk/itm/Triumph-Tiger-1050-Tiger-Sport-Rear-Brake-Caliper-Stainless-Steel-Slider-Pins/293476101210?hash=item445489ec5a:g:h8kAAOSwKAFeQtpw
I always strip front and back calipers every year to clean the pistons and copper slip the pads, but now also check the rear slider pins.
Lithium grease on the slider pins attacks the rubbers, causes them to swell, use silicone brake calliper grease.
Reply #11 on: 25 February, 2020, 07:50:29 PM
Yep, coppaslip knackers em too. Ive always used the original Red Rubber grease
Reply #12 on: 25 February, 2020, 08:38:51 PM
*Originally Posted by Timbox [+]
Yes coppaslip is mineral based anorl, I use it on pad retainer pins.
I use red rubber grease for fitting inner tubes on me traillie. Works a treat, no pinch punctures.
Last Edit: 25 February, 2020, 08:41:37 PM by Paul2bikes
Reply #13 on: 27 March, 2020, 10:01:32 AM
I did solve the issue with rear brake. After an overhaul they were fine but on checking later, rubbing a tad. Stripped the calliper again, found nowt wrong, so did a thorough clean of the slider pin & shaft the pin goes in, right in the bottom was some thick yellow grease, cleaned that out, greased the pin with calliper grease & all has been fine since. Teach me to skimp on a job eh.
Offline Path
  • Bike/Model: 2011
  • City / Town: Worcester
Reply #14 on: 30 October, 2020, 12:21:22 PM
Do you have the EBC part number for the organic rear pads?
#15
Reply #15 on: 30 October, 2020, 01:45:12 PM
FA215/2 non-sport.
Offline Path
  • Bike/Model: 2011
Reply #16 on: 30 October, 2020, 05:06:13 PM
*Originally Posted by Sidewinder [+]
FA215/2 non-sport.
right on.  thanks!
