Author [ES] [MY] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Another Cracked Piston?  (Read 20465 times)
Re: Another Cracked Piston?
« Reply #150 on: 22 May, 2020, 12:21:03 PM »
No worries mate, likely a different tune for the speedy motor than the Tiger. Somebody will know about that.
Online gosling 1
  • Bike/Model: '08 Orange Tiger
  • City / Town: Connecticut
« Reply #151 on: 22 May, 2020, 12:23:18 PM »
The piston part numbers changed back when the piston issue was current, not sure if Triumph changed the design, supplier, or both. Personally, I think there was more to it than just issues with E10 fuels but we will never know the full truth. Other brands are using cast pistons in bikes that make much more horsepower than our Tiger without issues. The revised tunes seem to have less aggressive ignition timing, the low octane "neutered" tunes even more so. My 2008 Tiger suffered the "pinging" issue early on, had the "Brazil" tune installed which is now the lower octane tune. It was noticeably weaker in top end power but I think it saved my pistons. Hamlin installed the revised tune as soon as they were released. It gave back some of the top end rush of the original tune. He also did a compression and leak down test on my bike just before it was off warranty in 2010 just in case. All was good and ten years on, still uses little to no oil between changes.
Offline Freddy
  • Country: West Oz
« Reply #152 on: 22 May, 2020, 01:26:40 PM »
gosling is correct. It was Jim Hamlin's work that brought this catastrophic issue to the attention of Triumph USA, and his alone.   The problem was 'solved' by retarding the ign timing.  US ethanol fuel exacerbated the problem.  The 1050 Tiger's timing was more advanced than the Sprint, which didn't have the problem, nor the S3 due to forged pistons.
The best substitute for brains is ........what?
Offline Rhead
  • Bike/Model: 07
  • City / Town: Long Island, N.Y
« Reply #153 on: 22 May, 2020, 01:52:18 PM »
ditto on the above 2 comments. And to reiterate, Triumph replaced my 3 cracked pistons with cast ones, of which all cracked again, even though I used much higher octane fuel than required (93 vs 89) They then replaced those 3 with cast again, but this time I had Hamlin also download the Brazilian tune. No more issues after 130k additional miles.
« Last Edit: 22 May, 2020, 02:08:27 PM by Rhead »
« Reply #154 on: 22 May, 2020, 04:34:59 PM »
Jim tells it like it is eh.
Does the link work this way, see Jim's comment, Reply80
https://www.tiger1050.com/index.php/topic,19368.80.html
Online spope1970
  • Bike/Model: 08'&09' 1050 tigers
  • City / Town: Blythewood
« Reply #155 on: 22 May, 2020, 07:01:32 PM »
No punches pulled on that one that's for sure. I like it. He tells it like it is. And to his point, the trashed piston in my images is the middle one with just a small crack on either side of the wrist pin cutaway on cyl 1.
Online spope1970
« Reply #156 on: 30 May, 2020, 02:04:03 AM »
OK guys. I'm swapping sumps now. I remember having to re-torque the bolts shortly after I bought the bike and that was a common issue. Has there been a change to the torque specs on the later models that may be different than what my shop manual lists?
Asking for a friend
Thanks
Steve
« Reply #157 on: 30 May, 2020, 10:20:59 AM »
*Originally Posted by spope1970 [+]
Asking for a friend
Thanks
Steve
I wouldn't overtighten them, I'm always wary with ally castings. I'd go with a wee dab of blue loctite on the threads.
Online spope1970
« Reply #158 on: 30 May, 2020, 04:30:41 PM »
I was thinking the same thing Paul. I'd rather have to heat it a little if I need to remove it in the future then to replace the sump now.
Adding a few picks of the sump swap and misc.
Speedy on the left, Tiger on the right. Time for operation SumpSwap
OOOOH Pretty! This Speedy was well cared for
That gasket did not want to turn loose. Only the center left :087:
All prepped and ready. Now on to the cover
Day 2,getting an early start on the cover
A few bits from the tiger cover
Ah! I knew that missing piece of land would turn up eventually  :046:
Clean up Time
That didn't clean up so well
That's the side that matters. Since it's marked "OK" i guess we're a go.
Enjoy
« Last Edit: 30 May, 2020, 05:06:51 PM by spope1970 »
« Reply #159 on: 30 May, 2020, 05:06:32 PM »
I'm very envious of your workshop, you're well kitted out there.  :152:
