Author Cracked headers  (Read 819 times)
  • Offline Paul2bikes   gb
    • Tiger God  ‐    9453
    Re: Cracked headers
    Reply #10 on: 17 August, 2022, 07:42:59 pm
    *Originally Posted by leighz [+]
    so....do I stick with what I've bought or order the ones with the shoulder?
    Bike's done 23k. So the state of the headers surprised me. I do ride in winter in salty conditions but not often and not far
    Have since extended the stubby front mudguard as that probably exacerbated the problem
    For me, I'd get the OE studs & copper slip them & the nuts.
    Mine is a '14, done 27k miles, headers in quite good condition, not used if salt is down. I spent a winter in Glasgow, no way I'd be on a bike. I came home one w/e with 6" of snow on roof of car, still there when I got home, to the amusement of all the neighbours, who hadn't had any.
    I had a front fender extender fitted from new, so that probably helped save mine.
    When Triumph fired up again in early 90's they recommended to spray the exhausts with Motorex 645, now called Moto Protect & shine, I've stuck with using that. Spray the whole bike with it in winter.
    https://www.manhattanbikes.co.uk/shop/lubricants/motorex-products/motorex-moto-protect-500ml-formerly-called-645/
  • Offline leighz   gb
    • Tiger Member  ‐    98
    • #11
    Offline leighz
    • Bike/Model: Tiger Sport 1050 2013
    • City / Town: Glasgow
    Re: Cracked headers
    Reply #11 on: 17 August, 2022, 07:44:34 pm
    the stud shoulder does not pass through the manifold mounting hole
    will look into the motorex stuff
  • Offline Sidewinder   gb
    • Tiger Master  ‐    883
    Re: Cracked headers
    Reply #12 on: 17 August, 2022, 09:38:48 pm
  • Offline leighz   gb
    • Tiger Member  ‐    98
    • #13
    Offline leighz
    Re: Cracked headers
    Reply #13 on: 18 August, 2022, 08:12:35 am
    great - have ordered the square deals ones
    ....and then I get a notice saying they're on holiday until the end of the month. Balls. Summer ticks away...
    • Tiger God  ‐    9453
    Re: Cracked headers
    Reply #14 on: 18 August, 2022, 10:14:30 am
    Order OE from Fowlers & get them next day. Keep it simple.
  • Offline leighz   gb
    • Tiger Member  ‐    98
    • #15
    Offline leighz
    Re: Cracked headers
    Reply #15 on: 18 August, 2022, 12:59:18 pm
    No - that's far to sensible. I've succeeded in making this into more of a palaver than really necessary already
    (tbh - I couldn't find the part on the fowlers fiche for my bike  :027: )
    the shoulderless studs arrived so will use those to get me back on the road
  • Offline leighz   gb
    • Tiger Member  ‐    98
    • #16
    Offline leighz
    Re: Cracked headers
    Reply #16 on: 22 August, 2022, 05:25:52 pm
    ...and all back together
    new coolant while I was at it. The old stuff was a bit minging
    Took it for a quick spin to get and remaining air out of the cooling system and generally check nothing falls off. Intriugingly it seems to pick up more smoothly rather than the snatchy low rev throttle openings I'm used to. I wonder if the hole in the exhaust made the O2 sensor give out some bizarre readings that would change the fueling
    on a sad note the lovely popping and burbling of the holey old exhaust on the overrun is now gone
  • Online Tigermike   gb
    • Tiger God  ‐    2458
    Re: Cracked headers
    Reply #17 on: 22 August, 2022, 06:44:48 pm
     :152: looks good  leighz.
    What did you replace the old headers with?
    New aftermarket ones or a good used set?
     :031:
  • Offline leighz   gb
    • Tiger Member  ‐    98
    • #18
    Offline leighz
    Re: Cracked headers
    Reply #18 on: 22 August, 2022, 06:49:25 pm
    I just got my old ones welded up by a local exhaust guy. Replacements are rare on ebay and expensive (eye watering in fact - 750!!!) if you buy oem - assuming they're even available. Lextek make a copy without the balancer pipes and catalytic converter for a much more reasonable 300 ish - I'll probably buy some of these if my repaired ones don't work out
  • Offline Mike_B   gb
    • Tiger God  ‐    1158
      #19
    Re: Cracked headers
    Reply #19 on: 22 August, 2022, 07:05:13 pm
    The stuff of nightmares, that.   750 - I wonder if it is so much because it includes a new cat?
    Did he weld a plate over the crack or just run a bead of weld along it?
