Author Hendler Fork Seals  (Read 402 times)
  • Offline Woodie   gb
    • Tiger Master  ‐    292
    Offline Woodie
    • MBD (Multiple Bike Disorder) is a thing innit?
    • Bike/Model: Tiger 1050 Sport 2013
    • City / Town: Upper Bucklebury
    Hendler Fork Seals
    on: 08 August, 2022, 10:14:00 pm
    Has anyone else used Hendler fork seals? They came from a 't'interwebnetthingy supplier and were supposedly correct for my 07 Tiger. Unfortunately I cannot get them to seat.
    I've been trying for 2 days, I even admitted defeat and bought a proper fork seal seating tool, I usually use the old seal and a drift to get them into place.
    I couldn't get the to seat even without the stanchion fitted.
    Unfortunately my lack of progress meant I got a little careless and have now dented the chrome on the stanchions so I'm going to replace the fork leg (with new OEM seals )
    Just wondered if anyone else had used/had the same problems with this brand of seal?
    I never touched it, you can't blame me, it went off when I was cleaning it.
  • Offline Zevk   au
    • Tiger Master  ‐    349
    Re: Hendler Fork Seals
    Reply #1 on: 09 August, 2022, 10:05:49 pm
    Hi woodie
    6 months ago I also changed the fork seals and bushings (inner and outer) on my 2012se and had difficulty seating the seal even with the fork slide hammer you mention
    I used an aftermarket set “all balls” I think
    You may want to try to apply heat from a heat gun, silicone spray or  bearing grease when you try again…?
    Where will you source a new stanchion and how much will it cost…?
    Good luck with the repair
    RV90, XL250, XL500, GSX750ES, CB750SC, VT750, ST1300A...took a while...2012 Tiger 1050SE
  • Offline Mike_B   gb
    • Tiger God  ‐    1158
    • Bike/Model: Tiger Sport
    Reply #2 on: 10 August, 2022, 08:09:01 am
    My only experience of non-OEM fork seals was when a local workshop fitted aftermarket ones.  They failed again after no more than a week.  Took it back and they replaced them with OEM (for free - no complaints there) and no problems in tens of thousand of miles since.
    Bit of a bugger than the fork is damaged though.   :-(
  • Offline Woodie   gb
    • #3
    Offline Woodie
    Reply #3 on: 14 August, 2022, 06:04:37 pm
     Good news: Sourced OEM seals and fitted, easy-peasy. Knocked straight in, in about 30 minutes.
    Bad News: wasn't concentrating and fitted the  :172: Henderson dust seal by mistake... :138:  :012: . . Had to carefully sand the rubber on the seal down until it would fit. . Took hours.
    Dagnabbit!
