Home
Search
Members Map
Photos Gallery
Login
Register
Forum Rules
Forum Help
05 Jul 22, 20:57 PM
Please
login
or
register
Tiger 1050 - Main Discussion Section
Maintenance, Servicing, and Mechanical issues
12000 MIle Service
05 Jul 22, 20:57 PM
Pages:
1
2
Go Down
Author
Topic: 12000 MIle Service (Read 2460 times)
Nunky
Tiger Newbie
Bike/Model: Tiger Sport 1050
City / Town: Kidlington
Country:
Re: 12000 MIle Service
Reply #10 on:
11 May, 2022, 11:39:36 PM
Thanks TigerMike. I'll give him a call tomorrow 👍. Much appreciated.
Logged
nehpetsthegrey
Tiger Master
Reply #11 on:
14 June, 2022, 10:20:26 AM
Originally Posted by
Nunky
Same problem here in UK. Just been quoted £1,000 for a 12k service by main dealer.
Just got stung for £1600 for the 12k (including a pair of tyres. Triumph replaced the front discs and pads under warranty.) Warranty runs out soon so I am urgently looking for a proper workshop manual as I will be hitting 24K early next year even at current fuel prices.
Or the bike goes. £2000 per year servicing at a main stealer is robbery. 6k was £500.
Any leads ideas gratefully accepted.
Logged
Dusty ST
Tiger Supporter
Tiger Master
Bike/Model: 2017 Tiger Sport 1050
City / Town: Brighton, Sussex
Country:
Reply #12 on:
14 June, 2022, 10:46:15 AM
nehpetsthegrey
I'd be getting a tool kit and having a go yourself. Also means you can spread the cost, and buy parts that don't come in an expensive Triumph branded bag
Logged
08 Sprint 1050ST
Paul2bikes
Tiger God
Bike/Model: 2014 Tiger Sport 1050
City / Town: High Peak
Country:
Reply #13 on:
14 June, 2022, 12:26:18 PM
nehpetsthegrey
I'd have got the tyres done at a local tyre place, likely saved £100 there. And that warranty work separate job also or they'd lump the labour onto your service bill.
Think about what you are confident doing yourself, most of it is fairly simple. Then maybe just pay dealer to do engine service, all under tank stuff while they got it off to check valve clearances.
What did they do for £500 at 6k service?
Break the invoice down to labour & replaced parts, just what are you paying for? Are you getting your hat nailed on, or is it all the work you are asking them to do.
My TS had dealer 500 mile service free. Then I had an independent do the 12k at 14k, I service the easy stuff every 3k miles eg brakes, oil & filter, suspension greasing, etc. I used to do it all but can't be arsed with the big one any more. I doubt I've spent £2k on servicing over the past 20 years.
Logged
Hamilton
Tiger Master
Bike/Model: Tiger 1050 se
City / Town: BRISTOL
Country:
Reply #14 on:
14 June, 2022, 01:32:09 PM
I would find a good independent mechanic for servicing . I paid £130 parts and labour for an interim service in march , oil and filter , brake fluid ,brakes checked , bearings , chain adjusted and lubed . I was quoted £ 190 for the fork seals and fork oil to be replaced which I had done at the same time . Because he finished the work quicker he would only take £300 .
Logged
#15
indytiger1050
Tiger Supporter
Supreme Tiger
Bike/Model: 79 Honda 750L
City / Town: Indianapolis
Country:
Reply #15 on:
18 June, 2022, 04:49:17 AM
Dusty ST
Manuals in a sticky or 3, and a service sheet to along with what is checked at normal intervals. Most you can easily do, would add check every nut and bolt. I use (witness marks) to see if they move. Dab of paint, marker on the fitting and other surface. A nut, bolt backing out won't have the marks aligned. Perfect example would be the oil pan, side covers and the notorious front sprocket nut which only loosens once.
The fluid change can be a little harder but easily done. The hardest bit would be the valve gap check. It's not that big a pain but when I checked the speed triple at 56k miles 3 would have to be done to keep gap and a couple others might be worth doing.
The one thing I will warn against is letting the brake masters run dry, especially the front one. It won't pump air and getting it going can be a PITA. Several methods of changing brake fluid check the youtube.
Note the color of the coolant, anything other than a nice red, green etc has a brown tint flush with distilled water. Buy it at the big chain store costs a buck a gallon, flush until clear. Then run your choice of antifreeze.
Logged
Support the forum.
jkd102
Tiger Master
City / Town: Rolleston
Country:
Reply #16 on:
18 June, 2022, 02:30:13 PM
nehpetsthegrey
I would swap those new OEM pads for EBC HH before they stuff up your disks again.
Logged
Matt Black 17 Tiger Sport - SC Project carbon can, Nitron R2 Shock, Revalved forks with Ohlins spings/Oil, MWR-HE Airfilter, NGK Iridium Plugs, Radguard, Re-Trimmed seat, Fenda Extenda, 30mm Risers, Puig screen deflector & spacers, Heavy bar ends, JBQ Shifter, MFW Vario Pegs, SW Motech City Evo Tank Bag, Triumph Tankpad & Centerstand, TomTom Rider 450, Valentine V1 radar.
Mike_B
Tiger God
City / Town: Tonbridge
Country:
Reply #17 on:
24 June, 2022, 11:08:50 AM
Bloody hell, there's some crazy service prices being shown here. I'm not an amazing mechanic by any means, but it's well worth buying a Haynes manual and some tools. I do all routine stuff myself except valve checks - none of the basics are difficult, and once you've done it once you'll wonder why you ever paid someone so much to do it for you. Half-decent tools last a lifetime so they'll pay for themselves many times over.
Every 3-4 years, depending on miles ridden, I get the local workshop I use to do a valve check when they have it in for MOT.
Logged
Pages:
1
2
Go Up
Recent Topics
New member from the Netherlands
New Members
Yellow Dog
Today
at 08:32:54 PM
rear brake calliper / rear foot rest hanger
Wanted Board
Magnetman
Today
at 01:59:13 PM
New Member
New Members
Yellow Dog
Today
at 01:10:49 PM
Is there a "book" time for motorcycle maintenance?
mustangpilot
Today
at 09:32:23 AM
Tiger Sport 1050 2017 g.b. noise clunking
Tiger's Den - General Discussion
mustangpilot
Today
at 09:26:32 AM
Screen or no screen???
Modifications, Accessories, and Appearance
Budthewiser
Today
at 09:04:59 AM
Oil cooler
Emu721
Yesterday
at 03:56:06 PM
Triumph Jacket f/s and Triumph Tiger 1050 forks for sale
Parts, Accessories & Clothing For Sale
Godzilla1123
Yesterday
at 03:44:00 PM
