Author Topic: Battery switch problem  (Read 808 times)
Offline blackgoff
  • Bike/Model: 2008 Tiger 1050 ABS
on: 03 March, 2021, 06:01:17 PM
Hey peeps,
Due to various lockdowns my Tiger has not been used much in months. Anyway went to turn it over Sunday but battery was kaput - looks quite old so got a replacement. Fitted brand new battery today but when I turn the ignition on there's no action of any kind - ignition light/fuel pump. Thought I'd put old battery back in, which at least turned ignition on, but again nothing. Check all leads/connectors but can't see anything amiss  :027:
Is it possible I might have accidentally unplugged/ knock something out under the seat? Or is there some kinda weird procedure to fitting a new battery???
Any help gratefully received folks!
Re: Battery switch problem
Reply #1 on: 03 March, 2021, 06:58:35 PM
Charging a new battery before use is always a good idea.  Is it a sealed zero maintenance type?
Kill switch?  Check all fuses.
Reply #2 on: 03 March, 2021, 07:18:43 PM
Check the battery voltage with multimeter, what's it read? And what make/model battery is it?
Offline blackgoff
Reply #3 on: 03 March, 2021, 08:33:58 PM
*Originally Posted by Sidewinder [+]
It is the sealed zero type and have checked all the fuses. Turn the key and nothing turns on (dash/lights etc), so definitely not kill switch
Offline blackgoff
Reply #4 on: 03 March, 2021, 08:35:30 PM
Thanks I'll put a multimeter on it in the morning to see what it's reading  :047:
Reply #5 on: 03 March, 2021, 10:40:32 PM
Alarm?  Datatool?
Offline TCC
  • City / Town: St Ives, Sydney
Reply #6 on: 04 March, 2021, 12:53:05 AM
As has already been said - kill switch.
Offline blackgoff
Reply #7 on: 04 March, 2021, 11:54:23 AM
Thanks peeps - beginning to think the kill switch could be fecked, but would that cut all power from the battery?
Reply #8 on: 04 March, 2021, 12:07:08 PM
Any news?
Reply #9 on: 04 March, 2021, 12:15:46 PM
No, kill only disables fuel and ignition so instrument backlights etc should still be on.
With ignition on does anything work?  Lights, horn, indicators etc.
Checked the 30amp fuse on solenoid?
Does the new battery have correct terminals, +ve towards rear?
*Originally Posted by blackgoff [+]
Last Edit: 04 March, 2021, 12:23:19 PM by Sidewinder
