Author [ES] [MY] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: ECU Map for-Uk Tiger 1050 2010 SE standard filter with Delkevic 350mm  (Read 1733 times)
Offline Pupone185
  • Bike/Model: 1050 SE 2010
  • City / Town: London
  • Country: Uk
Hi Folks
can you please suggest the correct ECU Map for-Uk Tiger 1050 2010 SE standard filter with Delkevic 350mm. I have Tunecu with cable already....  :490: :440:
Thanks very much
Valerio
Offline JerryH
  • Bike/Model: Tiger 1050 ABS 2009
  • City / Town: MALTON
Re: ECU Map for-Uk Tiger 1050 2010 SE standard filter with Delkevic 35
« Reply #1 on: 05 July, 2018, 10:17:12 AM »
I'd probably go for the 20545 Triumph off road map, it's what I'm running on a 2009 model with a 350mm Delkevic can. Though thinking of changing as I've now done the air box mod but unsure which map to go for.
Online Yellow Dog
  • City / Town: AUCKLAND
  • Country: New Zealand
« Reply #2 on: 05 July, 2018, 10:25:42 AM »
*Originally Posted by Pupone185 [+]
Hi Folks
Thanks very much
Valerio
 :401: from the Farcebook
I had a similar set up to you and ran 20545, on my MKI Tiger, with a Booster Plug. Give it a try and don't forget that the tune is designed to run 95RON fuel  :028:
2018 TIGER 1050 SPORT (c8
« Reply #3 on: 05 July, 2018, 01:18:05 PM »
  :401: Valerio & JerryH to the Forum.  :152:
wow 2 newbies in 1 go..
so Jerry, whats your impressions of the 20545 map before & after you did the airbox mod?,  :084:
I have the same setup but with a SC Project can.
(apologies Yellow Dog - I know you have already given me your thoughts & recommendations  :431: ).. ooohh  95RON that's normal Unleaded isn't it?
Online Yellow Dog
« Reply #4 on: 05 July, 2018, 08:43:57 PM »
*Originally Posted by Tigermike [+]
91RON is the normal stuff, though I hear 91MIKE is as good as 95RON  :008:
« Reply #5 on: 05 July, 2018, 09:10:07 PM »
*Originally Posted by Yellow Dog [+]
Ha bluddy ha YD  :010:
That's 1 less pint I will be buying you when you get back to Blighty  :031:
Online Yellow Dog
« Reply #6 on: 05 July, 2018, 09:57:25 PM »
I've also managed to offend Ron too  :033:
Might need some guidance on the beer front. I'm sure my old favourites will no longer exist  :169:
« Reply #7 on: 05 July, 2018, 10:31:13 PM »
What, you mean like Watneys Red Barrel, and Newcastle Brown?   :001:
« Reply #8 on: 05 July, 2018, 10:52:55 PM »
So what did you drink before you moved to NZ  :187:
Courage, Brakespears, Fullers, Wadsworths, Whychwoods,
Probably Black sheep ale now eh ....  :164:
Offline JohnnyWheels
  • Bike/Model: 2012 Tiger SE (red)
  • City / Town: Jackson, Mississippi
« Reply #9 on: 05 July, 2018, 11:06:34 PM »
For reference, I run 20546 in my 2012 SE with stock can, dog bone airbox mod, CAT and SAI removed.
Runs just fine.
At one point I had a Delkevic installed and ran 20543, but switched back to stock can because I prefer the lower sound level.
2012 Tiger 1050 SE
